Freeway 6 changed my third selected webm clip (in the video inspector) to .mov during upload resulting in firefox not playing the clip. the clip plays OK when directly dragged to a firefox window.
Why? and how to solve this (bug?)
Very strange. Can you send the file in to support(a)softpress.com please? Also, you say the third selected clip. If you’re providing ogg and webm then you only need one. The main browsers that don’t support h.264 all support both ogg and webm, so using both is redundant.
Firstly I dragged a .mp4 videofile on the page. Then I used the inspector to select a second (smaller) .mp4 for phone, and for the third option I selected the webm file.
What happens when publishing, (monitoring the resource folder) is that freeway is duplicating the .webm file as a .mov file and telling the browser that it is a quicktime movie, which obviously won’t load in Firefox.
I tried to prevent this using the extended Item menu, but had no succes so far
