At the moment I am working out how to get truly responsive text (not just at media break points) (http://simplaio.github.io/rucksack/docs/#responsive-type) and I am using rucksack which is a plugin for PostCSS (http://postcss.org)
What I was doing was adding the PostCSS/Rucksack special styles on a specific less style sheet within freeway and then running the published files through Codekit.
Everything is working for example vender prefixes etc but Codekit doesn’t seem to run the Hooks for PostCSS/ Rucksack, or in fact any hooks. Sso I was wondering if anyone has managed to get hooks working. Rucksack is working through Terminal so I know it works but it’s a clumsy way to process files, so that was why I was trying to use Codekit to automate the process of publishing from Freeway and then for PostCSS to finalise the style sheets conversion into real css styles.
Has anyone had any experience on getting shell scripts to run within Codekit
Cheers in advance
max
