Has anyone else had any problems with freeway crashing at all??
I hadn’t had a problem, until recently, now it has crashed 3 times in the last few days meaning I have lost hours and hours of work. As I have been using it for and year and I haven’t had a problem before I keep forgetting to save.
VERY frustrated, any ideas on how to alleviate this?
It does really help to get into the habit of saving every few minutes
or changes, it can be hard to get yourself to do this at first if you
are not used to doing it (Goes for all apps), it really is easy with a
quick Apple-S every so often (few minutes while working at computer).
It also helps to close the file at the end of the day and then open it
again next day, this way all the changes will be written to the back
up file for that site, but if you do not close the site the backup is
not written up to date.
BTW, repairing permissions might help.
HTH
What has happened to your system in the last few days—anything added/changed by you?
Believe me I will do my best to get into the habit, I think I better repair the permissions. I have also noticed that a couple of times recently it has been stuck trying to open.
There is nothing that I can think of that I have changed on my system recently, and I don’t think I have added any new actions or any thing like that. It actually always seems to happen when I am repositioning a html or graphics box, using the arrow keys.
I will repair permissions and report back.
Thanks for your help.
