[Pro] freeway gallery and firefox help
Hello, i have uploaded my website and the gallery page is very messed up but only on firefox and not on safari. I have used file zilla to remove all files and then re upload on a fresh screen but still no luck. Please help and please speak as easily as possible as i have some internet experience but not much. I have no idea what to do please help thanks.
http://mjdesigns.info/slideshow.html
Can you explain in more detail what you mean by ‘messed up’.
Please remember that you know what it SHOULD look like - but unless you tell us…
Also have a look at Colored graphic background breaks apart and displays with lines or blocks through it - Freeway - Softpress Talk
and Graphics shift down the page or have uneven gaps between them when previewed - Freeway - Softpress Talk
Yes i can, and by the way thank you very much for the hospitality. The gallery is set up in a slideshow, and even when i use the other option freeway gives up it shows up the same. Anyhow it seems the gallery is stacked on top of each other only each one is a little lower than the other. When you move it up or down you can see the main picture but there is a trail behind it with the same picture behind it. It hard to explain, so please bear with me here. Also i found out that when i open another tab and say type in cars, and if i stay on that site for a few minutes when i go back to the gallery tab, the cars site is in the gallery. Then after moving the gallery up and down it goes away. I am using firefox 14.0.1. I have noticed the site is fine on other firefox versions, but not this one. Please let me know if i can do anything else thanks.
the gallery is layered on top of each and vertically offset an inch of so down the gallery. The gallery is 7 inches or so long.
