The following information was submitted from a form on www.bajanapple.com:
Salutation: Salutation
First name:
Last name:
Email address:
Contact number:
Company :
Please select your product: Please select your product
Double or single sided?: Doulbe or single sided?
Colours?: In how many colours?
Paper type: Paper type
Paper size: Paper size
Does your artwork bleed?: Does your artwork bleed?
How soon?: How soon?
Quantity Quantity: :
How did you find us?: How did you hear about us?
if other please state: If ‘other’ please state here
Further information:
recipient: email@hidden
sort: salutation, first name, last name, email address, contact number, company, location, product, double or single sided, colours, paper type, paper size, bleed, how soon, how did you find us?, if other please state, further information
required: first name, last name, email address, contact number, company
missing fields redirect: http://www.bajanapple.com/missingrequired.html
thank-you: http://www.bajanapple.com/thank-you.html
PLEASE NOTE: This is a message from the www.bajanapple.com web site
and has been sent from a machine and not a person.
Please do not reply to this e-mail as it will bounce.
The subject is set in the PHPFF action interface as is the error and thank you pages. Read the blurb at FreewayActions.com | PHP feedback form for the significance of naming your fields correctly too. ie name, email and subject (case sensitive) have a purpose. So instead of separate first/last name fields just have a name field.
If you have laid out your form in a table then the sort order will also take care of itself.
Also in your pickers leave the ‘value’ of the first picker in each list blank then you wont get Paper type: paper type if there is no entry. (I appreciate you want all fields filled in but probably unnecessary when it comes to ‘how did you hear about us’ etc.)
you pages. Read the blurb at http://www.freewayactions.com/product.php?id=019 for the significance of
If you want to have a “self-label” like Paper type as the first (empty) option, just add the FormFix Action to either the picker or the page. It tidies up a number of foibles that Freeway insists on (gives all form elements IDs to match their Name attribute, gives all Select [picker] elements the complete structure and proper empty values, etc.).
