Sue_Z
(Sue Z)
January 25, 2013, 1:17pm
1
Please help! I’m trying to edit a graphic on my website.
I have a logo I am trying to replace a different version of the logo (but keep the links all the same). I highlight the picture and then I try to replace it with the new one and I can not see to do that. I see the name of the graphic but no option to replace that graphic. I’m searching and I can’t find any information on how to do that. It should be easy? I am on Freeway pro 5.5 Thanks! Sue z
If you are trying to replace it with a new version then doble clicking the graphic on your FW page will bring up a dialogue box.
In that box there are 3 buttons (there are more) that say Resample, Update and Locate
If you want to change the Graphic use the Locate button to navigate to your new version. If you have edited the original file then use Update.
Sue_Z
(Sue Z)
January 25, 2013, 2:03pm
3
Thanks DeltaDave !
I see this…however it says status : detached and that is checked , should I uncheck that ? Do I then try resample or update?
Thanks for your help!
If the image is detached it means that the link to the original is broken.
You could try unchecking the detached box - FW may then ask you to locate the original but you may need to reimport the image into the container.
If it allows you to I would use Update if you are using a new image.
Sue_Z
(Sue Z)
January 25, 2013, 4:30pm
5
Thanks for your help. I ended up removing the graphic and staring over.
