On my Mac running OSX 10.13 beta 3, Freeway Pro 7.1.4 is now running but with some problem that I need clarification
When Freeway Pro start, the splash screen pop up but no content shown on the splash screen. There is only blank splash screen with text read: Not found: The requested URL /Splash/70/en/full.html was not found on this server.
Check for Update fail with a dialog read: Update Error! An error occurred in retrieving update information; are you connected to the internet? Please try again later.
The rest seems to be OK. My Internet connection is perfect as I am sending this post. What go wrong with this?
It seems from your email that the ColorSync problem (which others reported) has gone away in the latest beta - so that’s good news!
I don’t know why this is happening, but I believe there’s a checkbox which will let you turn off the splash screen altogether (“Don’t show again” or something like that). I’ve always done that (splash screens are annoying).
I think that “Check for Updates” was disabled because of a security problem in Sparkle (check for updates software) so this happens on any version of macOS. There are more recent versions of Sparkle, but they are not compatible with Freeway.
It would have been better if the option was removed entirely.
Fix please
The situation with Freeway is that it’s more useful for me to spend time working on a Cocoa (64-bit) replacement than on fixing bugs in the current version - unless they are critical. But I think it’s worth reporting bugs on this list, so that people can suggest workarounds.
