[Pro] Freeway Pro 7 ask for ColorSync and refuse to run as usual
I have reformatted my Mac and now it is running OSX 10.13 beta 1 (clean install) and I have to reinstall every apps from scratch.
I have installed Freeway Pro 7. After installed, I start the app, a dialog pop up stated that I have to install ColorSync from the Product CD.
My system is a clean installed OSX 10.13 beta 1. What can I do to get Freeway Pro 7 up and running again
Help and support please
Regards
Sanchai Thiewprasertkul
Bangkok, Thailand
Easy dont run beta, its not fully compatible
Regards
Bangkok, Thailand
What actually is Colorsyc, and why this us linked to Freeway Pro? Can some experthere explain please
ColorSync is a framework build into Mac OS. It has been there since the year dot (well, 89 or 91 or so). It’s interesting that your beta install is missing it, but betas are not for the timid. I would roll your Mac back to a production version of the OS and wait until the next version is a little more baked. I doubt sincerely that ColorSync is going away, since it’s a foundation element in the OS – it ensures that colors render faithfully.
I’ve experienced the same problem. I installed macOS 10.13 High Sierra, Freeway Pro 7 won’t start. Prompts me to install ColorSync™ from the product CD.
But: the ColorSync utility is installed! I can open it, use it…
I guess, since Freeway is no longer updated or supported, there won’t be any chance to use it ever again.
So you didn’t read all that text that was displayed to you before installing beta software?
The point of beta software is to find problems with it before it goes on general release. So the idea is that you report these bugs to Apple and they try and fix them prior to releasing the gold master. That’s it. There is no other reason to install it, other than I suppose idle curiosity. FW runs just fine on the current release of the MacOS.
Maybe it’s been moved so it’s not where FW expects to find it. At El
Cap it’s in /Applications/Utilities, but over the last few releases
some Utilities have moved into /Library/…. If that’s the case a link
(and maybe the odd extra folder
should fix it.
Of course I did read the texts and I know what beta software is for. I am a developer and of course I already sent feedback to Apple. Let’s just wait and see.
@David thanks, I will try that!
My guess (I’m not using the High Sierra beta) is that this could be a problem with the way that Freeway detects the presence of ColorSync - in which case I expect we will fix it.
Jeremy
Maybe it’s been moved so it’s not where FW expects to find it. At El Cap it’s in /Applications/Utilities, but over the last few releases some Utilities have moved into /Library/…. If that’s the case a link (and maybe the odd extra folder
should fix it.
List Options | FreewayTalk
I’ve made a small change to the way that Freeway tests for the presence of ColorSync. Is there anyone here who can test this with a High Sierra beta?
I tried emailing Justin but haven’t heard back.
Jeremy
Jeremy
should fix it.
