[Pro] Freeway Showcase
Hi, is it possible to remove the thumbnails from the slideshow? Thanks Simon
Hi Siomn,
yes. You just have to go to the original gallery you created with showcase, open it, select the image you want to remove and delete it. After that, save your file again and export it to Freeway. Go back to Freeway, select the slideshow and import the new file.
best,
Marcus
Hi Simon,
Although you can’t hide the slideshow thumbs using the action interface you can add a simple bit of CSS that will do this for you. Here’s how;
  1. On the page(s) with the slideshow select HTML Markup from the Page menu
  2. Select “Before end head” in the Insert popup
  3. Paste the following code into the text area (ignore the lines that contain the tildes if you are reading this as an email rather than online)
<style type="text/css">
.fwShowcase_wrapper { display:none }
</style>
  1. Press the OK button
    Now when you publish or preview the the thumbnails should remain hidden.
FreewayActions.com - Freeware and commercial actions for Freeway Express & Pro.
http://www.freewayactions.com
Sorry, Simon, I misunderstood your question. I thought you were talking about removing one thumbnail from a gallery.
Thank you Tim, that’s a question I also had.
Best,
Marcus
On Dec 13, 2010, at 3:34 PM, Tim Plumb wrote:
Hi Simon,
</style>
One quick question: How can I add an extra markup page for the slideshow if I already have one markup page for the CSS menu? is there a way to add multiple markups?
thanks i advance,
Marcus
Hi Marcus
You can hide the thumbs in a slideshow by selecting None in the “Thumb Position” popup menu in the action palette. Here’s an example:
http://users.softpress.com/joe/showcaseFun
thanks i advance,
Marcus
HI! Can you tell me how they did this with the slideshow on the monitor? It’s very cool. I don’t have the option to click “NONE” in my thumbnail layout mode. I only have right, left, top and bottom. I don’t want thumbnails to show.
Thanks!!!
Hi Marcus
You can hide the thumbs in a slideshow by selecting None in the “Thumb Position” popup menu in the action palette. Here’s an example: http://users.softpress.com/joe/showcaseFun
This pic shows where you set your Thumb position
I don’t have that option. I wonder why not??? I only have TOP, CENTER and BOTTOM. No NONE. I have the latest update.
Have you chosen Slideshow from the Type option - 3rd one down.
My version is 1.6.7 which I believe is current.
well, son of a gun. There it is! THANK YOU!!!
