[Pro] ftp-upload problem
If i try to upload my page, i get this error message:
That’s what i tried:
ftp-mode passive, non-passiv and auto: all fail.
Upload with filezilla: ok
On this server i have some more pages and the freeway upload is no problem.
Anybody an idea?
You can find this website here: spopi.de jetzt kaufen!, it works fine.
Sorry - cant read German - can you translate the error message for us.
wow David, your’e very quick.
The message says:
“Remaining objects: 126.
Connect to spopi.de.
Can not complete upload, because the host could not be resolved.”
Hubert
It sounds like you are having a DNS problem. Can you please try the following in Terminal.app?
host spopi.de
followed by
traceroute spopi.de
There is no need to do the second one if the first one fails.
The message says:
Hubert
If this needs further explanation, what I mean by try is, “type this line, then press Return, and look at what is printed back to the screen”.
There’s probably something wrong with your settings,
Not here when trying to reslove spopi.de, took > 1 min to open the page.
/ Omar
::: Communication to improve civilisation :::
s_ip
The message says:
Hubert
Settings change is needed on the DNS server: check to be sure that you have a DNS A record for spopi.de (without the www) and a CNAME pointing www.spopi.de to spopi.de. Alternatively, you can do this in the other direction, with an A record for www, and a CNAME for the domain, but I think that’s harder to do.
/ Omar
s_ip
The message says:
Hubert
I take that back, your DNS is configured correctly, so this may be a connectivity issue, or perhaps configuration on the FTP server side of things. You have a full A record for both www.spopi.de and spopi.de, both pointed to the same IP address, so that’s not where the issue is happening.
/ Omar
s_ip
The message says:
Hubert
What do you have in the directory path for your upload settings? Not password or user - just directory.
Having had this on my small german Freeway board some months ago.
The solution there:
Use “passive” mode (always and nothing else) and even if you already tried it - try it again.
here is the trace log:
MacBook-Pro:~ … host spopi.de
spopi.de has address 81.169.145.159
spopi.de has IPv6 address 2a01:238:20a:202:1090::144
spopi.de mail is handled by 10 mailin.rzone.de.
MacBook-Pro:~ … traceroute spopi.de
traceroute to spopi.de (81.169.145.159), 64 hops max, 52 byte packets
1 10.0.1.1 (10.0.1.1) 6.069 ms 2.401 ms 2.185 ms
2 87.186.224.189 (87.186.224.189) 48.227 ms 47.758 ms 46.939 ms
3 87.186.250.118 (87.186.250.118) 47.911 ms 48.410 ms 47.576 ms
4 194.25.6.62 (194.25.6.62) 130.200 ms 50.881 ms 51.048 ms
5 xe-3-0-1.atuin.as6724.net (62.157.249.198) 50.869 ms 51.285 ms 51.022 ms
6 xe-10-3-0.morla.as6724.net (81.169.144.33) 51.959 ms 53.069 ms 87.004 ms
7 te4-2.fiddlersriddle.as6724.net (81.169.144.34) 52.896 ms 53.804 ms 52.580 ms
8 w9f.rzone.de (81.169.145.159) 53.030 ms 52.669 ms 51.885 ms
MacBook-Pro:
I’m confused because FW-upload with other websites on this server ( spopi.de jetzt kaufen! or spopi.de jetzt kaufen! ) works fine.
Are you using these folders as sub domains?
And to reiterate
@David
Here are my settings: Dropbox - Error - Simplify your life
@Thomas
danke für den Hinweis. Aber ich hab’s schon mehrfach versucht. Erfolglos.
Hab’ übrigens viel von Dir gelernt …
(Webdesign/FW-User seit 8/2011)
Hubert
well Hubert, I hope uploading hadn’t been part of … :slight_smile:
Remove the ftp. in front of server (you already chose the ftp as method).
Port 21 (was standard in former times)
Remove the slash in directory ( I think if it should be in front).
Finally choose passiv(e) as recommended and it should (ooohhh) work.
Thomas,
i followed your instructions and … it works.
Thank you.
PROBLEM SOLVED
Hubert
I have upgraded my freeway 5 Pro to freeway 6 and now I can’t upload my pages to my server. I have no problems uploading Freeway 5 Pro to my server but now that I have upgraded to 6 I do. I have called my server and told them about this issue and have never came up with a solution. I’ve done the same things FTP mode mode positive, non positive, Port 21 and still no luck. I don’t know if I have to change my settings or what to do. The message reads just like H.Banken reads" cannot complete upload because the host could not be resolved".Can someone help me please.
Rss
Rss,
Try contacting Softpress support with your bug. The FTP option works for me!
In the meanwhile upload to a local folder then upload that to your web server using a dedicated FTP client.
Caleb Grove,
I called them and talked to a rep thats who sent me this FreewayTalk Link.
Are there some settings i need to know about?
