[Pro] Full page background
Hi I am interested in creating a full background (photo) website, which is adaptable with the proportions of the page to an extend.
Is it possible to create something similar with Freeway Express?
http://www.normann-copenhagen.com/
Try the “full background proportional” action
http://actionsforge.com/actions/view/141-full-background-proportional
Hi Rich,
thank you for your help. This Action is good and almost does what I am looking for. I would like if possible if the image stopped “shrinking” when it reaches its minimum size. This action allows the image to shrink freely, but the problem is that in the end, the background (colour) appears. Do you have another solution?
thank you
Dear all,
could somebody help me? I would like this action to work in the same way: full size background that adapts to the page dimensions but when it reaches a minimun size the background should stop shrinking (like in the example I previously gave). This way I would avoid the colour background to appear on the bottom of the page when using the action “full background proportional”
Can you post a link to your online example
This action: bgSupersizer. As used here http://snellvilleautotrim.com/index.html
You would think that after 35 years Pat would have been able to come up with some better pictures of his Auto work!
D :wink:
@D haha. I told him that and he’s been taking pictures daily. Gotta love his own hand lettered windows also. However, his upholstery work is outstanding.
I am sure it is - and I would love to see it, especially in some classic cars.
Hi all,
thank you! this is exactly what I was looking for!
I was wondering if with this action I can link each image from the slideshow to buttons hyperlinked to each photo inside the page.
for example, when you enter a product page, the page has 4 buttons to different images of the product. When a button is clicked the button changes color (showing the image selected). I wanted the slideshow to change image but also change the button, matching the link to the image.
does this make sense? :slight_smile:
thanks again!
