Does anybody know if there is another action out there that i can use to show the images on the full screen.
Right now I am doing by copying the images on a white background 2560 x 1325 px. then i use Background Supersizer to display the image…It works fine on a computer but on tablets or phones it can get complicated.
Is there another action that adjusted to the different devices.
Thanks for your time
Best
Torben
http://www.torbengiehler.com/PAINTING/2013/lysoli2013.html
Hi,
honestly I can’t figure out on what you’re after (I remember you already posted something like that, correct?) - so if I misunderstand this, apologize.
I am under the impression that the bg-supersizer is built to exactly display fill-screen images. But it is only able to do if it is hooked on items that have attribute(s) of 100% width, such as a background of a page eg.
So it might be, that this is an issue of basic-construction rather than a missing “action” in its classic sense.
Unfortunately, me personal need something like an example to give you more infos (a link to a page that inspired you).
I once used the action underlying “original” script, but honestly this was purely hand-code far off any WYSIWYG experience - so nothing to recommend at that time.
