[Pro] Fuzzy text in OS High Sierra in FWY Pro 7.0.4
I just bought a new iMac with OS 10.13.6 High Sierra. I noticed that when I opened Freeway (Pro 7.0.4) the first time, the text in the FWY app looked a bit fuzzy in the items, the Site Panel, Inspector, etc. It wasn’t unreadable, but it was notably less sharp than, say, when previewing that same web page in a browser.
Is this a known problem with FWY 7.0 in High Sierra? If so, might it be solved by my moving up to FWY Pro 7.1.4? Or can someone suggest some other cure to sharpen the font text in the FWY app? Thanks.
Hi Jim,
The slight fuzziness is because Freeway’s UI hasn’t been adapted for high-resolution “retina” displays.
You can upgrade to the latest version of Freeway (7.1.4) for free. It contains some important bug fixes compared with earlier versions.
Jeremy
On 18 Jul 2018, 10:11 am, Jeremy Hughes wrote:
Hi Jim,
Jeremy
Thanks, Jeremy. Will do. And that explains it.
