will the new 5.5 version fix the problem of FLASH virtual reality tours not playing on IE 7 and 8?
Hi Robert
as far as I know freeway and flash vr’s are fine
here is an example
http://viking.servon.co.uk/gallery/
max
Hi Max
thanks so much for responding to my query
your work is very good!
what application did you use to create the FLASH panos
I use Pano2VR to make FLASH vr movies
previously when I uploaded a FLASH virtual reality panorama movie using FW 5 PRO it played on all PC browses except IE 7 and 8, so I wanted to know if FW 5.5 solved this problem. I also use Dreamweaver CS 4 and the FLASH panos uploaded work fine on IE 7+8
I have customers that want full screen FLASH panoramas (no zenith or nadir) with the ability to play on smartphones and computers. I prefer FW to Dreamweaver but have to go with the application that causes me the least headaches.
Thanks again for your response.
Take care
Rob
Hi Robert I have emailed you directly rather than through this post
kind regards max
