HI,
do I need to use any sort of special procedure to transfer my FW work from one machine to another one?
HI,
tend to say noop, as long as you make sure that all the relevant actions, images and fonts used on the old machine are available on the new one as well.
Caveat:
You probably need to re-link all resources to get the correct new paths for all your image stuff (if it wasn’t part of your project folder which is often the case).
If you do a File>Save Archive of a FW doc then FW will wrap up all the images and other media for you into 1 package and when you open the file on your other computer it will all be in the correct places.
But - as Thomas says - you will need to make sure that the same actions, fonts are available too.
