I have been using the CSS menu action successfully for some time, but since updating to FW7 submenus appear overlapped or in the wrong position. Has anyone else experienced this?
If the menu is absolute positioned in a relative positioned parent, this can happen cause by default, FW7 doesn’t declare position by default anymore (we had a discussion about that a few days ago).
Thanks for your suggestions and I apologise for the slow response but I have been away.
You can see the problem at www.tonyhatt.co.uk. The menu on the home page is all over the place and on all the other pages the drop down menu under landscapes is overlapped. I have tried various settings in the action panel but nothing solves it.
It worked fine in Freeway 6 and I have other sites which use CSS menus which I am reluctant to upgrade to F7 until I can find a solution.
