I have recently updated to Sierra using the latest updated Freeway Pro and everything appeared to be working well until I hit a snag. I want to add a gallery using Exhibeo 2. I have built the gallery and exported it to Freeway but I cannot import it as it is grayed out. Didn’t have this problem prior to Sierra. Any suggestions please?
Yes definitely using the the Exhibeo 2 import action. When I go to File/import the titled called, in this instance Gala.xbExport, is grayed out and cannot be imported. Not sure if this a Sierra problem or 7.1.4 problem or both.
If you still have ExOne, use that. ExTwo sucks big time. Too many bugs unsolved, and nowhere near a finished product. Otherwise you might want to take a look at the competition.
– Richard
Thanks for the suggestion Richard. Have just tried that but exactly the same problem, exporting the file to Freeway is like the Exhibeo 2 example, grayed out. It seems it is not compatible with Sierra.
Has anyone used Exhibeo2 successfully with Sierra I wonder?
Which competition should be tried? Advice would be appreciated.
