I have a colleague who has just bought her first copy of FWPro and A MacBook and the bottom of the FW pane with the quick links is below the Dock. How can she bring that up when you can’t see the resize corner?
Usually, if you click on the green ‘gem’ button at the top left of the
window, the window resizes above the dock. You may have to do this
twice, if it creates a ‘too small’ window, first time. (Or drag out to
size).
HTH Colin
corner?
Click the Resize button in the toolbar, the one with the plus. You may need to click it twice. Alternatively go to the Window menu and choose Tile or Stack.
Try the Apple menu (top left) dock - position either left or right. This will give you access to the bottom of the Freeway pane which you can re-size. Once change revert the dock to the bottom - if require.
I understand that Freeway will remember the pane size when you re-open - but perhaps a whizz may confirm this.
