[Pro] GoDaddy Questions
We’re working on a site where the client is hosting on GoDaddy. I know there are some problems with using them and I have some questions.
I’m using the PHP Feedback Form Action and there is a GoDaddy check box. Is it necessary to use it, or is that to use in case there’s a problem with the form not using it?
I’m also using WebYep on the site and I think Dan Jasker said something about a possible permissions problem. I’m not sure what the permissions are supposed to be and how I would change them if they are incorrect.
Thanks.
Bob
if it works without then don’t worry but I am afraid the likelihood is that it won’t work unless you do.
In fact it would probably be a good idea to get a request in for an audience with the Pope because divine intervention is the next step!
No clue about the permissions issue.
In conclusion - does your client really need to be hosted there?
Yeah, I’m afraid so. They have another site hosted there and I’m not sure how long they signed up for.
Bob
it really isn’t a proper consideration as hosting is cheap and the time you save by hosting elsewhere will easily make up for the extra cost.
Dave, the site I’m building for a friend is hosted by GoDaddy, too. I was wondering what you meant about time being saved by hosting elsewhere? And do you have any recommendations for other hosting services; there are so many of them it’s really difficult to pick one that might be excellent or at least a lot better than many others.
Martin
Signal Mountain, TN
There are a couple of fellow Freewayers here that offer very reasonable hosting services.
David Owen at http://www.ineedwebhosting.co.uk/ and James Wilkinson at http://www.have-host.com/
They both are FW users so understand the problems that you guys come across.
What I mean about time saving is that both these guys run Industry Standard linux/unix hosting packages where you don’t have to jump through hoops just to make what should be an out of the box action like the PHP Feedback Form action work. It just does! Unlike on GD.
With both you have access to another Industry Standard - CPanel - which allows far greater flexibility when it comes to adding server side software such as CMS, Shopping Carts etc. - usually with one click. Also you have access to and control over features such as Password Protected Directories, Email Spam protection, Database Management, Site Statistics and so much more.
David Owen has a CPanel test drive facility at his site so worth a look just so you can see what they both have to offer.
David is UK based and James in Canada so if it concerns you about having support in your time zone then here are 2 options.
Right, I recommend having your domain with GoDaddy and your hosting with HostGator, but you may want to wait as HostGator is going to be a domain registrar with cheaper prices than GoDaddy for domains. I know once I hear that is complete, I am switching my domain over.
