[Pro] Google Analytics
Does anyone know if Google Analytics can be applied to an object within a page. My customer wants to measure how clicks the ad receives. See link for site in question
Thanks John
http://www.lovelandbiketrail.com/
See if this helps you
Thanks I will give it a read.
Anyone familar with:
Tag your page for enhanced link attribution
Add the tag to your tracking code, after you create a tracking object, as illustrated by the red text in the example below:
ga(‘create’, ‘UA-XXXX-X’);
ga(‘require’, ‘linkid’);
ga(‘send’, ‘pageview’);
I assume I have to go in with Text Wrangler and add this code/
Thoughts. Thanks JOhn
Try this again. How do a add this code from Google to an image?
You’ll also need to add (or modify) the onclick attribute to your links. Use this example as a model for your own links:
Check out example.com
I tried “Mark Up” and it does not work or I am doing it wrong. I know I have to change out “www.example.com
Thanks John
