Jack1
(Jack)
1
Error message:
“Oops! Something went wrong.
This page didn’t load Google Maps correctly. See the JavaScript console for technical details.”
is this a freeway issue?
thanks,
jack
(sorry for the excessive posting)
http://new-wave-academy.com/aboutus.html
It’s the new Google Maps requirements…
These are the steps to get a working API key
Login to https://console.developers.google.com
Now you get a popup with the API key (a string a gibberish).
To use the API key you need to tack it onto the script load, such as:
David Owen { Freeway Friendly Web hosting and Domains }
http://www.ineedwebhosting.co.uk | http://www.PrintlineAdvertising.co.uk
On 2 Jun 2017, at 16:18, Jack email@hidden wrote:
Error message:
thanks,
jack
Jack1
(Jack)
3
Thanks for your reply,
I follow all the way until “tack it onto the script load”
How do I do this in freeway?
http://www.softpress.com/kb/questions/191/Using+the+Google+Maps+Action
