I have built an iphone mobile site, using a freeway template, and am having problems with the quality of the graphics. They look great in Freeway but once uploaded, they look grainy and unfocused. I have played around with quality % of jpegs, I have changed file formats and even fonts created as graphics in Freeway look grainy and unfocused.
Any help or ideas would be greatly appreciated.
TS
No background color set. Anti-Alias check box is ticked for graphic items and set to auto for html items. My graphic designer built the logo in, I’m assuming photoshop. I have imported the graphics by drag and drop as well as import and I get the same result.
So is it a jpeg or a gif or a psd? If a jpeg then unless you import as a pass-through then you are jpegging a jpeg - which will lead to loss of quality.
Best to import a psd (or a tiff) and let FW only compress once or resize/scale in PS and import as pass-through.
But I suspect that your text quality issue is anti-alias related.
Also if you look at my page http://www.deltadesign.co/examples/stark.html and compare it to yours you will see that your logo has been dispro’d (disproportionally scaled). There is something about your page that is causing this squashed effect.
Try a new blank page with just the image on it.
Also I think you would get a better quality image if you output as a gif from a lossless Photoshop/Illustrator format.
