Do graphic effects, such as borders, drop shadows, and glows not work in inline layouts? I basically have a jpg placed in a graphic item, within an HTML container and I cannot get the effects to work.
99% of all stuff within Freeway works for inline layouts too. I only stumbled upon a few actions that exclusively need layered construction such as ScriptyFader.
Weird. For whatever reason I cannot get any of the effects to work with an inline layout. Would you mind emailing me the Freeway document you used so I can try to deconstruct it?
But things like these are a JustWork. Simply try this on a blank (master) page within your project (just for testing purposes):
Place there your graphic item, and style it as you like (should do or not?).
Select this item, hit CMD-C, go to your current page, click in the box you’d like to insert the item so you see the flushing cursor and hit CMD-V.
Tell me what you see.
A blank page (usually as a master) is anyway a good idea for backing up some stuff, making some clean development of single stuff and bring it later in place (or sometimes not)
Nope. You can only apply the effects to a normal image, because they get burned into the image itself, and the pass-through images are not modified in any way. You can do some sorts of effects with CSS, take a look at my CSS3 Shadow Action for one example.
On Jun 21, 2012, at 12:50 PM, RavenManiac wrote:
No worries. I think I may have discovered the problem. Can you use pass-through images with graphic effects?
