[Pro] Graphic to Video Clip Link - problems
Can someone please advise. I have retrieved WMV Video Clips from an old website and am using them on my new Freeway website (www.alboradadance.org) Video Clip Page. It appears that some of the website viewers are experiencing difficulty in viewing the WMV link. To try and resolve this problem I made an additional link (converting the WMV file to Quicktime) and using an additional graphic to link to the new QUicktime file. Although it takes a long time to load Quicktime, it is, nevertheless viewable on my PC and my MAC, both in IE v9, Safari and Firefox but apparently some of my viewers cannot see the WMV. Some see it but cant hear it - some say their machine freezes. Can someone advise me. Any solutions, please? All the best - Mike
Can you post a link and tell us what Browsers/Operating systems have problems.
Are they using Goole Chrome on a PC. I now have to grant ‘permission’ per site to view Quick Time using Chrome on my mac, yet .flv fly right through.
I recently checked a group of mp3s that are clustered on a page (with the extended: autoplay/false added):
http://www.class-e-ads.com/GOAcss/giftofangereventsandlinks.html
and only in Chrome on a PC do they all take off from page load (anyone have a solution?).
Frank H.
To Delta Dave and Frank H - thank you so much for your very prompt reply
Delta Dave - the machines appear to be all PCs running Internet Explorer - although my wife has a PC running Firefox which now runs the movie but without sound (another viewer of the site complained of the same thing).
There does not seem to be any particular pattern here - I have a PC and the clips run on IE, Safari and Firefox perfectly. It seems to me that the problem lies either with their PCs running with something other than Windows MV or they dont have Quicktime or their settings may be blocking in some way or other. Hard to determine. Have you experience of this? The strange thing is that the WMVs were playing fine on the old site which was created with CUTESite builder (which, as you may know, went out of business some years ago)
Frank H - I will try and check to see if they are using Goole Chrome.
Any input very welcome - thanks, Mike
Yes but what versions of Browsers and operating systems ie Vista and IE 7 etc.
These are critical to know along with a web address so that we can see underlying code etc.
Hi Dave - give me a day or two and I will try to get this info to you. - I did start a survey but I seem to have mislaid the results. - Mike
And a link meantime?
Hi Dave - I am sorry, I am new to this. What do you require as a “link” - my email address? or the website’s address? The website is Alborada Spanish Dance Theater’s website at:
www.alboradadance.org and you may use my email address of" email@hidden
Thanks for your help Dave and I am trying to get more info on this for you.
I am using a 27 iMac OS X 1.1.1 running Safari 5.1.
My PC is Vista 32-bit Home Edition using Firefox latest version.
The wmv clips on PCs running IE (I suspect a lower version like 7) appeared saying that Quicktime needed a component from the QUicktime website which was no good. The culprit seems to be older versions of IE - although Firefox had its problems on some machines - just giving vision but no sound. I will come back with further details when I get them.
Mike
Yes - a link to the page at www.alboradadance.org so that we can see the problem for ourselves.
I think I would convert these to MPEGs - you are probably going to get more consistent results from them across browser/platform.
And you would only need 1 file type.
Your current conversion process may be lacking in something (codec?) and that is why you are getting inconsistent results.
Dave - thank you for that input. My current converter is Smart Converter. I will try what you suggest. Thanks again.
Mike
SmartConverter certainly outputs MPEGs as MP4 files.
Try one and we will try it.
Hi Dave - I tried the MPEG (since deleted from the website) - it took far too much CPU usage to be practical for everyone - in addition to this, it was sluggish video and no sound whatsoever. I am not sure what to do from here on out. Any suggestions? Everything works fine on my Mac and PC. I am in the middle of my survey with known viewers and will get back to you with the results. Thanks for all your help.
Mike
I tried the MPEG
What size of file is your original vs the MPEG?
The biggest of the three was 44 mb (MPEG) as compared with the original of 31 mb - Mike
still waiting for results of survey
