Hello everyone. Recently I’ve purchased Freeway Pro 5.5 and I love it so far. I’ve read many posts on these forums when I’ve had questions and you guys seem very helpful and have solved alot of the problems I was having just through others having the same issues. This one though I think I might need a little more help on. I have a website home page I’m working on that can be viewed here … http://lhd2tb.dyndns.info/reflections I am using the graphic blue water jpg underneath the Reflections jpg logo with the flexible image action on the water so it will expand and contract on varying screen sizes. That all works fine, but the problem I’m having should be easy to spot, it has an area of blue around the words. The actual image was made over a transparency and saved that way so it should have no outline color. I should mention it worked fine when I just had a color in the background instead of the image. I’ve tried many ways to use css, mix and match css and table, basically everything that I could think of and that is the best I could get. It should still be ok but I’d like to know if there is a possible way to get rid of the blue around the edges. I hope I’ve made clear the problem I’m having and any help is appreciated. Thanks in advance.
If you change the image to a PNG with Million of Colors instead of a GIF, the problem should clear up. Select the logo graphic and go to the Item Output Settings tab in the Inspector, and you can change the image type and colors there.
Cheers,
Katie Wagner
Technical Support Operative
Softpress Systems Ltd
