[Pro] Growing Height Breaking Background
I need a little help here. When the text area grows in height on my contact page, there becomes a gap between the box background and the box border. Here are my settings: http://cl.ly/image/400f1C3E0K2R
And here is the link:
http://www.onrampwebdesign.com/contact.html
You need to set the background color of the div element ContentBox to match
the color used elsewhere.
Ernie,
For some reason, I’m not quite “getting” what you’re saying. Maybe you could re-phrase it?
You must be using an action to generate the “rounded corner” look on your
page with images. So ignore what I said, state the action you are using,
and hopefully the author or another user experienced with that action can
help work out how to resolve your problem.
Best of luck.
On Wed, Dec 5, 2012 at 12:56 AM, Caleb G email@hidden wrote:
Ernie,
could re-phrase it?
Ernie,
No action at all, just Freeway’s inspector palette.
CloudApp — Not Found
See the “corner” under graphic effects?
Hi Caleb,
What is the overflow setting in the Inspector palette for the main text area?
You can fix the issue by setting the overflow on the div ContentBox_m to auto with some CSS (see below) but you should be able to do this in the Inspector. The graphic effects on the box have chopped the page up quite a bit and I’m wondering if the overflow has been lost in the process.
Here’s the manual fix with the CSS;
http://www.freewayactions.com/test/onramp/
Add the following code to Page > HTML Markup > Before ;
<style type="text/css">
#ContentBox_m { overflow:auto; }
</style>
Experienced Freeway designer for hire - http://www.freewayactions.com
Facepalm
All I had to do was de-select the height field in the inspector.
Thanks a bunch for your help guys!
