[Pro] Guides in FW
Hi,
I was wondering if anyone knows of an easier way to delete the guides that you draw in Freeway other then picking them up and dragging them back to the ruler?
Is there a way that a can select multiple guides and delete them at once?
I want to delete the guides not just hide them.
Thanks for your help.
Amanda
Hi Amanda,
You can create a bunch of guides in one go from the Create Guides dialog. More information can be found here:
You can either remove all guides at once with the Remove Guides menu option, or if you double click on a guide you can remove them one by one. There’s no way to select multiple guides though I’m afraid.
On 19 Jan 2011, at 03:51, Amanda Stretton wrote:
Hi,
Amanda
Thank-you, that has saved me heaps of time.
Joe–
Maybe that “Remove Guides” should be under a different menu like the “View” where all the other guide functions are. I looked there first to remove all the guides and I didn’t know about it since it was in another menu.
Just a suggestion or Feature Request.
A valid point, thanks Dan.
On 20 Jan 2011, at 03:26, Dan J wrote:
Joe–
