When trying to setup h1 tags this is what I am getting in the code… is this right, if not, how can I change it? I’m just trying to get heading setup for when i do my actual text, just using filler text now
              If you are just trying to create h1 tags then that is fine - though you seem to have an h1 around a space as well as the line that starts Nulla…
              Yeah, just trying to create the h1 tags. I want the h1 tag around where it starts “nulla” but for some reason its adding it to the part before it, any ideas?
              I figured it out, turned out there was that space, and you can’t have that, no big deal. No my question is, how long should the H1 tag be? Is the 160 characters too much?
              A short line of text that conveys meaning.
              Gotcha, So it can say " h1 class" and still count as a h1 tag? Just want to make sure
” h1 class” and still count as a h1 tag?
They are 2 different things
h1 is a Tag - class is a Class
It really means ‘this is an h1 Tag that has the class of ???’
So you can have an h1 with any class that you like it does not detract from it being an h1 Tag.
              Also,how would this work for the site i just showed you?
Main Heading
 Is this the "nulla"
Secondary Heading 1
 " about us"
Sub-section of the secondary heading 1
 "paragraph under ut
Secondary Heading 2
 our services
Sub-section of the secondary heading 2
paragraph under?
              so google will still see it as a tag then, thats my question, if it doesnt,how can i turn it into a tag?
The class is irrelevant!
              As long as google recognizes it as a tag then thats cool with me!  what about those heading setups? Am i on the right track
              I haven’t even looked at your page.
              oh, well when you can, id appreciate it, just trying to get a handle on this h1 stuff
I think that you are missing a trick here - why not have your graphic header as real text and make it your H1.
eg change it to
 H Grant Design for Speed, Quality and Personalisation.
Then you could make your ‘Nulla vitae elit libero, a pharetra augue. Praesent commodo cursus magna, vel scelerisque nisl consectetur et. Cras mattis consectetur purus siamet fermentum.’ into an h2 explaining a bit more about H Grant Design
              I could do it that way, but i want to keep the background with the speed.quality.personization part. I feel like it gives more a “cool” feeling to it. I feel like too much text is overabundant
You can set the image as a background to the html container that holds the text - no excuse!
              If i set the image as a background, won’t the text not show then?
It shows just now doesn’t it?
              That whole thing is an image, I made it in photoshop
That is my point entirely - images have no real SEO value. You are better off with real text.
So - undo the layers and just use the bg.
