I’m creating an h1 heading but the text appears bold when I have not actioned that, how do I correct this?
Bold is part of the default setting for h1. You’ll need to edit the h1 style in Freeway and click the ‘Extended’ button and enter ‘font-weight’ in the ‘name’ field and ‘normal’ in the 'value field. All without the quotes of course.
best wishes,
Paul Bradforth
Buy my eBooks at:
http://www.paulbradforth.com/books/
Thanks Paul, maybe you can help with another one I’m struggling with?
In html text, sometimes I need to put more than one space between characters, when I hit the space bar several times, it shows OK in page view but in preview and when published it reverts to one space, any cures?
regards
Steve
best wishes,
Paul Bradforth
Buy my eBooks at:
Hi, it's ebOOxa
Yes; use Option (Alt) space instead; this is a ‘hard space’, and will be recognised by the web, unlike multiple ordinary spaces.
best wishes,
Paul Bradforth
Buy my eBooks at:
Further to my recent reply—in what circumstances do you need to do this? It sounds like something there might be a more ‘proper’ solution to. For instance, it’s not a good idea to do this in order to make things line up on the page, if that’s what’s happening …
best wishes,
Paul Bradforth
Buy my eBooks at:
