Where the grass stays fixed but the page flows under the grass.
It seems creating a fixed footer is fine and dandy in Freeway using 0px bottom, but when you create a html text box to go under the footer that is longer than the pasteboard page, it then breaks it when publishing the page, and fixing it to the top.
Maybe it can’t be done and I will use code to do it. But any Freeway workaround would be helpful.
No need to hack it, just draw an item (layer) at the bottom of the page, set the Position value to Fixed in the Inspector palette and make sure it is positioned from the bottom of the page rather than the top (click the Bottom Inset button in the Dimensions section of the Inspector).
Ahhg… I know where I was going wrong. I was floating and fixing an image to the bottom of the page. If I float and fix a HTML box div to the page bottom it works.
I can then spacebar-drag to absolute position my images into this div. (Just love this spacebar Freeway trick - you can even nudge images to create minus positioning to hang things outside of the surrounding div)
A div can be fixed to the page bottom (with a div of underling text underneath), and if you move the Safari window the div sticks to the bottom of the page.
HOWEVER… if you use the scroll bar it does not, the fixed footer moves up as you scroll.
Really? It doesn’t for me, it always sticks to the bottom regardless of scrolling.
On 11 Dec 2009, at 16:58, WebWorker wrote:
…oh no it does not work completely.
How did you get your footer to have position:fixed? Freeway seem to give me position:absolute on the Footer. I think this is where I’m getting the problems
