[Pro] Hard drive failure and accessing an existing FWP website
Hi, in the event of a hard drive failure with no backup, is there zany way possible to retrieve website hosted files and open a Freeway Pro 7 document or because Freeway generates html on the fly during upload am I stuck at recreating the website from scratch, obviously using what elements I can access?
Is there a way to edit the home page temporarily even if it’s using tools other than Freeway Pro?
Thanks in advance - L
As long as you have the site files (HTML, CSS, js etc.) on the server they can be easily pulled and edited in a proper text editor, but you will not be able to open/edit them with FW. If you’re able to recover the local FW file you should be ok, if not you will need to rebuild it in FW or use a tool that can handle the source files natively.
https://creativ.space
https://xiiro.com
