I’m quickly running out of space on my 2012 MacBook Pro internal hard drive. I currently have the stock Apple 500GB, 5400 RPM drive. Not sure of the cache size.
I’m considering an HGST TravelStar 1TB drive with a 32MB Cache that runs at 7200 RPM.
Has anyone upgraded their laptop from a 5400 RPM drive to a 7200 RPM drive? I’m concerned about heat, noise, battery life, etc.?
I’m pretty sure the drive I had in my 2009 MBP was a 7200. No problems with the issues you mention, though it was having intermittent reliability issues and I’ve recently replaced it with a 500 GB SSD, which I really love.
I’m jealous. I just upgraded one of my MacBook drive bays to 256GB Samsung 840 Pro, which I also love, but it’s only 256GB. I’m putting the 1TB drive in the second bay.
Have you enabled TRIM on your SSD? I’m told it really helps with performance.
Just ordered a Travelstar. I’ve had a LOT of success with the Deskstars in my server, so I figured I’d stick with the same brand and up the speed to 7200 RPMs. Thanks for everyone’s help.
