[Pro] Have an item display on the page on click
Hi guys,
I am wondering how I go about having a item display on the page on click (the same page as the on click item).
I have gone through all of the actions and can see that some of them might do what I want but a lot of the actions don’t seem to come with instructions so I am not really sure what I should do or which action I need.
What I want is to have html text links to a couple of html paragraphs that will load in a specific spot on the same page as the text links but that will not be visible until the links are clicked and will only be visible one at a time.
Your help with this is much appreciated!
Amanda
While this is easy with a graphic item it is not so easy when HTML text is used.
The target show/hide layer action should be used on your layer that contains your HTML paragraphs with a simple rollover on the graphic trigger.
Inserting the action ‘text rollover’ into a run of text will give you the same trigger but only on mouseover.
Example http://www.deltadesign.co/odds/textlinks.html
Thanks for your direction David, I sorted it out.
