First, try using a Markup Item (draw it on the page or insert it inline within an existing HTML item). The Page / HTML Markup doesn’t give you any control over the positioning of the frame, and it sounds as though you may have pasted it into one of the markup “slots” that is outside of the visible page. Second, you may want to use the Iframe Action (available at ActionsForge) and when you use that, you only have to paste the URL for the iframe contents into the Action pane, not the entire blob of code.
On Apr 25, 2015, at 3:52 PM, Howard Spaeth email@hidden wrote:
This is a code I am getting from a site:
How do I embed this? When I put the url in there, it does not work. Is there a specific way to embed an iframe, I tried through HTML Markup
Yeah, I used the Iframe action and it worked a lot better! Just hope the site is mobile friendly, I did not try that out, but when I went to the site on my phone it is!
