Hi All
I’m using the Backdraft ‘fiveWrapper’ at the bottom of the page and what I need to do is to get a single image in the centre of the wrapper - see link
First of all: Can it be done. Secondly: How would I do it?
Regards
Lee
http://www.cherokeedesigns.co.uk/test/visitor/accommodation.html
I see single images in the centre of the wrapper. Thats NOT what you want
then?
Op 21 jul. 2014 10:29 schreef “Gray Owl” email@hidden:
Hi All
link
Regards
Lee
then?
Hi Andries
Not sure what you mean but ‘fiveOne, fiveTwo, fiveFour & fiveFive’ have to removed so that leaves ‘fiveThree’ in the centre of the ‘fiveWrapper’
Regards
Lee
ok, you only want to show Five three in a Five Wrapper?
Op 21 jul. 2014 11:15 schreef “Gray Owl” email@hidden:
then?
Hi Andries
Regards
Lee
Correct. It’s only because I don’t have any more links for that page at present.
Regards
then I could think of the following:
Select the item “fiveOne1” and go “item → extended”, and there the tab DIV-style.
Insert in Name-field “visibility” (without quotes) and in value-field “hidden” (as well without quotes).
Repeat this for all the items that shall not be visible.
If you want them to be displayed later, don’t forget to remove this extended style (keep it in mind).
Gray_Owl2
(Gray Owl)
7
Thank you Thomas, that worked.
Lee
