Help!!! For some reason is my PHP feedback form action missing from my menus… The strange thing is that when I open an old design were I used it in, it shows in the page>page action menu but every thing new made (even a blank for the template menu) it does not show up… I’m pulling my hair out on this one.
Did you upgrade to a new version of Freeway? If so, you will need to install any Actions you used in the old version in the new version. Freeway 5 and 5.5 (which goes up to 5.6) store their Action files in a folder named Freeway 5, which is in your Application Support folder in your Library (a normally hidden folder in Lion and Mountain Lion). Freeway 6 uses a folder in that same directory named Freeway Pro. While you could just move or duplicate the contents of the ~/Library/Application Support/Freeway 5/Actions folder into the ~/Library/Application Support/Freeway Pro/Actions folder, you would be missing an opportunity to update your Actions. Many changes between these versions at the Actions API level, and lots of Action developers have spent many hours either taking advantage of them, or cleaning up their old work so it will run at all on the new hotness (raises hand).
The reason why your old documents show this Action is because the Freeway document caches a copy of each Action used within it. This is there as a safety net for that time when you are using someone else’s computer to edit your site, and they haven’t installed all the Actions that you have. This feature is fraught with peril, by the way, best not to rely on it too heavily.
