You’ll need to alter the PHP code for that. This line:
{{figure_title}} — Posted <time datetime="{{datetime}}">{{posted}}</time>
does everything for the link text. Edit it to be what you would prefer, and you’re all set.
If all you want is the name to appear, you would make this line only {{figure_title}}.
If you don’t want the list item structure around the links, you can do that two different ways. One would be to edit the PHP so it just makes a sentence rather than a list (the list has certain usability benefits, though, I wouldn’t recommend getting rid of it entirely. You could also use CSS to make it appear to be a sentence. In the li style you made, add one more attribute pair:
display: inline;
…and that will remove the return after each item. They will simply become one massive run-on sentence.
The file names are simple. You just rename the actual files on your server. Any underscores in the filename will be converted to spaces, you don’t want to use any spaces in a filename, naturally. So if your comic was called ‘A_meeting_in_the_dark,_in_the_park!.jpg’, it would appear in the list as ‘A meeting in the dark, in the park!’ Just remember to upload or rename these one at a time, slowly (so as to separate their modification dates from one another) in the reverse order that you want them to appear. The sort order is most recent = first.
On Mar 8, 2012, at 4:38 PM, Joe Vissichelli wrote:
I also need to alter the file names, maybe just using the numbers or a new name, but definitely getting the dates off the list. How would I change that?
Can the list also appear in paragraph form – in other words, just the numbers separated by spaces?
Sorry to work you here, but I hope it’ll help others as well.
tutorials mailing list
