On Mar 13, 2012, at 12:56 PM, Joe wrote:
I re-downloaded the gistfile, renamed it list.php and replaced the old one with it. The list is now cleaned up:
http://zakmakestracks.com/test1.html
Now it’s a single vertical column 10 lines high, so I still need a change to get the “paragraph” look I want. I had addressed this once before with Tag-only styles > Extended > display: inline, but that seems to have no effect right now. Not sure what to to mess with right now.
I’m also wondering how to gain control of the side margins in the list box, which are always wider than I want regardless of padding settings. Padding is now 0 and still wide on the sides, though the top and bottom are fine.
You don’t seem to have a matching style on #item2 ul – that’s where your padding is coming from. Look back through this thread for the attributes you need (padding-left: 0) and make a new style for the list (ul) itself.
The style that you do have on #item2 li seems to be formatted badly, so it’s breaking all the other styles in the same block. Make sure that if you use the Extended dialog that you don’t add any curly-brackets to the fields. If you read this CSS example on the Web somewhere:
#someId tag { margin: 0; padding: 0; }
That would translate into Freeway as (assuming you had Edit Style open):
1. Click Extended.
2. Click New.
3. Enter 'margin' in the Name field, enter '0' in the Value field.
4. Press OK.
5. Press New.
6. Enter 'padding' in the Name field, enter '0' in the Value field.
7. Press OK.
8. Press OK.
A lot of clicking, to be sure, but the point is that Freeway will create all of the colons, semicolons, and brackets – all you add are the names and values and let it format everything else.
Thanks to some web research, I’ve also set the preferences in TextWrangler and TextEdit to proper settings to avoid future screwups. Don’t need to add confusion.
tutorials mailing list
