[Pro] Hosting + web-yep
Hello,
Wondering if anyone can recommend a host that works well with web-yep. I’ve been pulling my hair out with my current situation…(see my previous post, http://www.freewaytalk.net/thread/view/50737")
The folks at web-yep have told me that a finding a new host might be the best answer…any suggestions?
Rich
I have had no problems using WebYep with http://www.ineedwebhosting.co.uk
and its service is very Freeway friendly - with the principal behind
it being a regular contributor this list.
I also use http://www.fasthosts.co.uk and have had no problems there,
either, (except one of my own making!).
Colin
On 6 Apr 2009, at 20:37, Rich Gannon wrote:
Hello,
We have a lot of Freeway + WebYep sites running on our servers. I’m
happy to be of help to you if you need it.
regards
On 6 Apr 2009, at 8:37 pm, Rich Gannon wrote:
Hello,
Rich
David Owen ::
Freeway Friendly Web Hosting and Domains
If you don't find an answer on this list, here's another place to
inquire:
It's a forum of site builders and resellers.  There seems to be a
lot of knowledge and experience over there.
							Peter
Thanks for the info. In the end my host came through and fixed the problem.
Clook works well with webyep for me
http://www.clook.info
http://www.clook.co.uk/services/
regards
Brian
Peter Saint James said recently:
If you don’t find an answer on this list, here’s another place to
inquire:
http://www.webhostingtalk.com
It’s a forum of site builders and resellers. There seems to be a
Peter
Rich
I use Have-Host for a customer and have WebYep Successfully running and
working well for my customer. I would suggest you contact James
Wilkinson at http://www.have-host.com/ His prices are also right.
Andy
Rich Gannon wrote:
Hello,
Rich
One.com and Bluehost.com both work well with Webyep…
The simple fact is that any decent host that are using unix etc servers and recent versions of PHP should give you no problems.
You are far more likely to have problems with hosting companies that are using Windoze boxes.
