[Pro] Hover.css
Hi Guys,
I was playing with these nice hover transitions;
To add the effect to an exicisting div class in the tutorial (http://ianlunn.co.uk/articles/hover-css-tutorial-introduction/) they explain;
“The element already has a class of “button”, so we added the secondary class of “hvr-float” next to it, separated by a space”
Tried to add this extra style in Freeway but this doesn’t seems to work? Has any one a solution/ tutorial for add extra classes to excisting styles?
Thx for your help
Erik
Freeway doesn’t allow you to apply more than one named (class) style to an object using the user interface, but if you know the existing class applied to an item, you can enter two or more classes manually using the Extended interface. Click once on the element so it shows its corner handles, then choose Item / Extended from the main menu, and click on the
(or other tag name) rather than the
tab. Click New, then in the Name field enter class and in the Value field, enter your space-delimited list of classnames: button hvr-float.
On Jun 11, 2015, at 5:36 AM, Erik email@hidden wrote:
Hi Guys,
Hover.css - A collection of CSS3 powered hover effects
Thx for your help
Erik
List Options | FreewayTalk
Tnx Walter try that!
There are some nice effects on that site, Erik. Thanks for making me aware of it. Please keep us posted how it goes implementing into FW!
