How can I make the images in this carousel look much better/sharper?
• Images exported as PDF High Quality from InDesign CS6
• In Freeway, Settings in the Graphic Items Box;
Type: PNG
Col: Millions
Bilinear
Anti - Alias
Any help appreciated
Tony
http://goo.gl/RYlIQR
Can you not export them from ID in a better format than PDF to bring into FW
Can’t help feeling that PDF is not good for an image and the double conversion is losing you quality.
Sorry not an ID user so not sure what your export options are.
It’s probably transparency flattening - open your images in Photoshop and
flatten them, then resave. See if they are still clumpy.
If they are clumpy going into photoshop, then maybe export them from iD as
jpegs instead.
Type: PNG
Col: Millions
Bilinear
Anti - Alias
Tony
