[Pro] How do a allow customers to send files to me
How do a allow customers to send files to me directly for my website?
What sorts of files are you talking about Tony.
Usually a customer/client would just email a zip of associated files or provide a dropbox link to a shared space.
If you are considering some sort of web upload to your site then you should think very carefully about this. Your site is likely to be hosted on shared server space and as such any files β€˜uploaded’ to that space can put all the other sites on that server at risk if the files are not checked/sanitised correctly. You dont really want to be responsible for bringing down a whole server - potentially hundreds of sites - do you?
Give us more information about what you are trying to do and we can give better targeted advice.
Hi Dave
I would like to place a file upload link on this page: http://goo.gl/DlCJPs
β€’ with the ability (on my part) to download this at will
β€’ or have it download to us autmatically
We need to receive large files at time from customers as we are graphic designers so I’m trying to make it easier and more convenient for the customer to do so.
A file upload link is quite common on a printers website.
Tony
Hello Tony,
There is a link to β€˜Send a Large File’ on the page already is there not?
Which takes you to a page with a range of options for clients to upload large files.
The methods listed offer a variety of ways for clients to send files. What is it you wish to do thats different from any of these at all?
Just curious.
Anthony
Hi Anthony
Required: the ability to upload a file directly from a form on the website.
Sure - but these uploads are generally well protected/sandboxed so that no malicious content can get through.
Without correct protection you are putting potentially hundreds of other sites at risk.
How would you feel if another site on your shared server received a malicious file that took the whole server (including your site) down?
It is doable but it is not a step you should take lightly.
Interestingly I found 607 domains hosted on the same web server as yours.
A lot of sites to risk unnecessarily.
I do something vaguely similar where members can upload a variety of file types (controlled by me) using a (slightly modified) file manager. Although the upload process is slightly different the end result is essentially the same.
Ideally your file uploads would be stored outside the site root where they could automatically be scanned and if necessary, quarantined. When I say β€œoutside” it could be above the site root (same server) or even better, on a completely different server where there is no way infected files can cause problems. For example, Amazon β€œdumb” storage.
While not excessively difficult to setup it would require a fair bit of tech work.
If you decide to upload straight to your site root then at least make sure your host has some sort of (manual) virus scanner in place so you can run it daily. A2 Hosting has a decent scanner The Best Web Hosting Services at 20x Speeds | A2 Hosting but as far as I know it can’t be configured to run on a schedule. But I could be wrong.
Office (Chicago): 312.212.3955
Ok, thank you all for your help. I’ll contact my ISP and see what they can offer.
