like this…
ie: with a graduation and lines fading to white
thanks
like this…
thanks
I made a screenshot of the background used in your sample website. Cropped it to 18px wide in Photoshop because that’s where the structure is based upon. Check the media folder in my example for the file.
Used this file as background image in Freeway Pro. Tiled horizontally and set the vertical tiling to top. This does the trick.
Here is the file I used, so you can see what I did to achieve. http://dl.dropbox.com/u/248835/Background%20sample.zip
DTP2
Looks good, cheers mate. Appreciate it
