Please forgive me, if this is really simple…
I want to add little animated banner to a website. I’m using MotionComposer to create the animation, which produces some HTML code. Then in FreewayPro, I draw a little HTML box of the same dimensions, drop in the Mark Up code, & the animation appears when I preview the page in a browser. But now I want to make that whole box a hyperlink, so that when it’s clicked it takes you to a different page on the site. MotionComposer is supposed to be able to add the action to the banner, but their documentation is weak, & when I do everything they suggest in their video, it still doesn’t work.
Since I’m making the HTML box in FreewayPro, for this banner to nest in, I thought, FreewayPro should be able to assign the action to the whole box. Hopefully this assumption is correct.
When I have the box selected in FreewayPro, the hyperlink option is grayed out in the menu bar. All the actions have other options, like open a pdf, or something other than what I want.
wow, there’s no edit feature on these posts?
ok, well I found the layer button easily, & your idea works perfectly in Preview In Browser.
However, when I upload the site, the banner disappears but the invisible link is still there. I figured I had to upload the little folder the banner created, so I used ftp. But not sure which folder to put it in on the server… I guessed public_html but that makes no difference. The banner is supposed to work with html5 or flash. It works perfectly in preview mode, but that’s it…
Post a link to your online page and we can tell you where to put it - probably in the same folder alongside the HTML page that it is supposed to appear on.
If you look at your markup code you should see this
<iframe src="file:///Users/riseabove/Documents/2ndSt.Studio/UpcomingEventsBanner/mzFrame.html" width="400" height="64" frameborder="0" name="MotionComposer" scrolling="no"><p>Your browser does not support iframes.</p></iframe></p>
You are trying to link to a file on your Mac - not on the server.
This assumes that you have uploaded the mzFrame.html page to your server along with the folder you talked about. If mzFrame.html is in a folder with the other files then it would read
