I’m getting a 550 error (permission denied) when uploading to the Server. I checked the ‘Save Log’ checkbox in the upload dialog - but where can I find this log so that I can establish what happened in the last upload session?
Depending on what system you are on you might have to use the Finder’s Go Menu ie Go> Go To Folder and type in /Users/yourusername/Library - once you are in the Library folder you will be able to find the Logs/Freeway Folders
