Hello all, some help and guidance needed on how to achieve this in freeway.
As part of a shop I am building for a client selling cookies.
I need to achieve something like this where the client can select the type of cookie first and then opt to add personalisation, for an additional charge, and collect the name for personalisation. I have found on malsforms an example of the sort of thing I think I will need to build.
I put this together using my Mals Actions (http://www.freewayactions.com/product.php?id=016) which allows you to mix and match items to build quite complex buy forms. This example could be further extended to check the user entered the required text into the text field using the Validate Actions.
Feel free to contact me directly if you have any specific questions.
That is perfect, I have already got a copy of your actions but was struggling to work out how to use them and put it all together. I am using freeway pro 5.6.0. I am about to sit down with your manual now my sons are in bed to see where I am going wrong!
