[Pro] How to add rel="canonical" tag
Hi,
I’ve been taking some SEO advice on how to make some improvements to my site. One of the suggestions is as follows, and I quote:
“I’ve noticed that some of your most powerful backlinks point to the non-canonical version of your homepage. If you implemented the rel=“canonical” tag across your site, you might gain more value from links that point to these non preferred URLS. You should also update all internal links to point to the homepage (”/“) rather than the “/index.html” version.”
Google’s webmaster central blog talks about the canonical tag here:
Does anyone have any neat and quick ways to add this tag using Freeway? And how can I update all my internal links to point to “/” rather than “/index.html”? Is this possible in Freeway?
Hi eidetic,
You can add it to your pages by going to the page menu and choosing HTML Markup. A dialog with a dropdown menu at the bottom of it will open up, select “After ” from the dropdown and paste the link tag like so:
You will want to change http://www.examle.com for your domain, and add the path to page if you’re adding it to a page other than your homepage.
Hope this helps,
On 31 Mar 2010, at 17:23, eidetic wrote:
Hi,
Official Google Webmaster Central Blog: Specify your canonical
And to get links to the home page to be to the folder name rather than
the index.html, you can use the External side of the Edit Hyperlink
dialog, and enter a single slash in the URL field. I’m not sure why
Google is recommending this behavior – a link to a folder gets a
redirect by Apache to folder + default index page (usually
index.html). This is more work for the server, and strictly speaking,
not a true URL at all.
On Mar 31, 2010, at 2:08 PM, Joe Billings wrote:
Hi eidetic,
tag like so:
homepage.
Hope this helps,
Hi,
Hi eidetic
I realise this is an old post, but can you tell me if this worked ok?
I want to do this as well: " You should also update all internal links to point to the homepage (“/”) rather than the “/index.html” version.”
And just want to see what benefits this has brought and if you recommend doing it?
Many thanks,
Mark
