[Pro] How to create Sub menus
I want to create a Navigation sub menu, i have searched the KB etc and cannot find anything that explains how to create a sub menu. I also looked at the Actions site and nothing seems to answer the question there either. I can find references to CSS Sub menus but nothing on how they are created.
I have found an Action called BAM but there is little or no documentation about how to use it.
Some assistance would be appreciated.
John
There used to be a video tutorial about this…but the link to it at the end of this page no longer works.
At any rate the URL below has some instructions on how to create navigational menus with the CSS menu action.
Hi,
THank you for this i am working my way through it at the moment, still not sure how to do the Sub Menus but will work it out hopefully.
John
When you create your list for your menu you indent once to create a sub menu twice for a sub, sub menu
Select the list item and use the indent button
That example is from the 2nd menu on http://www.deltadesign.co/menu_stuff/menutest.html
Dave,
Got it thank You
John
