Hello everyone,
I was hoping someone would be able to suggest a way to create a product menu like this one:
http://www.squashedsoftware.com/products-ntp-clock-sync.php
in Freeway 5 pro.
Mike
Hi Mike this is done with JQuery
its applying the effects via the product-scroller.js file
its a nice effect and can be done within freeway, although if you aren’t comfortable dissecting how something works and replicating its function then it may be a little difficult unless one of the standard effect libraries like mootools or scripty has this function.
Max
Check out Dan Jasker’s screen cast, JQuery 101. I have very limited coding abilities, but was able to follow along and create a similar sliding effect.
http://www.danjasker.com/store/
And this one uses Cmotion Image Gallery from Dynamic Drive http://www.dynamicDrive.com
http://www.deltadzine.net/test/cmotion.html
Thank you Max, Rich, and Dave. I will get to work.
Mike
