I am working on a revision of a website using the BAM.
I was wondering how it is possible to have a slightly smoother movement when it is triggered.
Also for the items under ‘the Gorbals develops’ submenu I’d like to only appear when the heading is moused over.
Is this doable.
I am looking for ways to extend BAM and such things as styling of submenu’s and motion of sub menu items would be one of the things I’d like to improve on.
This site is a work in progress I should add!
Many thanks.
http://www.thegorbals.co.uk/untitled1.html
Just thought I’d add to this that after setting up the menu and testing it I then set it up on my master pages of the site.
The submenu contains rollovers on each of the headings and although they are fine on the master pages on each and every page of the rest the rollovers are allover the place! Othere than going through all of the pages and resetting the rollover options on every item then I can’t see what else I can do.
Is there a way for me to achieve the same effect as I have in this menu without using rollovers or is this something which can be resolved with my existing setup? I am not sure why the rollovers are so affected and not functioning as they should be.
Any insight would be much appreciated.
Hello again.
I have tried to resolve this still with the BAM action but still the master page version of the BAM looks fine until looking at the actual pages where the rollovers are not as they should be.
Is there any reason that master page items such as those in the BAM are not appearing on the Master Page based pages as they should be?
Hopefully I am explaining myself clearly enough.
many thanks.
